CS102 HO seagull has not been used for 19 years
Richard Freund
Post by Richard Freund »
I am trying to renew this seagull which hasn't been used much. It is unable to get gas from the fuel tank to the bowl. I have cleaned the pipe on the motor and taken off the gas float and inserted a fine drill bit up to place where the shut off pin inserts. It seems to be clear of foreign material but I am unable to get gas to flow from the intake port to the gas bowl. any assistance would be appreciated. I have flooded the area with carburettor fluid. Richard Freund
Re: CS102 HO seagull has not been used for 19 years
Hi Richard
Can you post a picture of your engines carb, then we will have a better idea.
Thanks
Richard Freund
.JPG[/attachment]
That's a Amal 418 Alan.
Try compressed air throughout the entire fuel system.
Post by Stelios_Rjk »
I clean my amal twin jet after several failed attempts with pure acetone. One jet was filled with a sticky substance. Only acetone manage to dissolve it a little and finally managed with a needle to take it out. Α syringe with a needle might proved a helpful tool.
Stelios_Rjk wrote:I clean my amal twin jet after several failed attempts with pure acetone. One jet was filled with a sticky substance. Only acetone manage to dissolve it a little and finally managed with a needle to take it out. Α syringe with a needle might proved a helpful tool.
400 series Amal carbs, have quite alot of plastic components.
Acetone may dissolve the plastic bits, I am also carefull using carb cleaner as I have dissolved diaphrams in Land Rover carbs using that.
Richard Freund
I am trying acetone and see if it works Thanks to all
Richard Freund
Cleaners haven't worked but some one told me I am missing the piece that connects the gas hose to the carburetor Are these fittings available? I am uncertain as to the parts needed
Better talk to John his prices are better than that & don't forget the fibre washer, is the filter gauze there?
Richard Freund
I have tried to contact john at the web site and phone number listed to no avail. If possible would he contact me at 62freund@gmail.com
mrford
Post by mrford »
Hi Richard It looks like you are missing the banjo housing if you try the auto parts shop they were used on some M G s on the break system this might fix your problem / Hope this helps VIC
Richard Freund
I haven't done much lately in repairing the gas connection to the carburetor but I have made a new cap with 1/2 inch copper pipe fittings. I now need to find a gasket to fit this connection/. Any ideas?? Copper pipe fittings seem to fit very well to the carburetor
mrford
Post by mrford »
Hi very innovative now take a manilla tag and make some gaskets use an exato knife go slow this will get you buy ! A paper clip some bubble gum and off you go . marvelous simple machines !!!
