after much cursing i have removed everything which holds this tube on...it has move around 5 mm but will not come off.
looked inside and only thing i can think off is the exhaust holder?
how does the square impellar shaft come off from the crankcase as i think it justs pulls off but i do not want to use too much force
aluminium tube removal
Re: aluminium tube removal
The main best idea is to Be patient, don't use force yet.
Can you post some pics so we can see where you are up to and give us your engine number?
It's a century Plus isn't it? You can keep adding to the one post by using the reply button; you may be replying to yourself as you make progress.
- Niander101
Yes give us more information or pics its a bit unclear what your saying
sorry chaps but forgive my terminology as this is my first seagull....anyway tube is now off and so is the square section rod that the impellor sits on.
engine alloy as now been cleaned and waiting for the next section to work on.
i must confess having steve from leeds marine within a mile from me is a bonus as he always answers my newbie questions so i do not cock up....many thanks steve
- Niander101
I once could not disconnect the drive tube from powerhead it was so rusted on to crank
had to cut off drive tube then grind away drive shaft from crank ..was left with a good powerhead.
