My new engine a 125
kitepaulx2
My new engine a 125
Post by kitepaulx2 »
Got a new engine and fired it up started very well so happy with that.
Not sure the prop is right, intact dead sure its a wrong un... any thoughts anybody have what I need, or does a century plus prop fit?
My work
http://www.freelancecooperative.co.uk
http://fiftyminusfive.co.uk
Re: My new engine a 125
That is a 125 prop, no other prop will fit & work without changing the prop shaft, and Seagull did not make another prop suitable for this powerhead.
Did you check the big end?
kitepaulx2
So no spring just a split pin then?
My work
Look at the inside of the prop it's got a rubber cushion hub, can't remember if it has a sheerpin as I scrapped my one as it had a dead big end.
Those engines are very prone to big end caps failing I believe. Suggest you heed CharlesUK's advice re the big end.
Don't rev it hard in neutral, or the big end could let go. You might be able to obtain a replacement big end cap of you ask around, as a few people have made them I believe?
Oyster 49 wrote: Don't rev it hard in neutral, or the big end could let go. You might be able to obtain a replacement big end cap of you ask around, as a few people have made them I believe?
:wink:
Post some pictures kitepaul we all like a few pictures.
Niander101
Post by Niander101 »
[quote="Oyster 49"]
Don't rev it hard in neutral quote]
Good advice with any engine!
That's a red line at 4250 maximum if the standard big end & crank journal is in perfect condition.
kitepaulx2
Ok no drive, have pulled the engine over with prop engaged but it does not turn any thoughts before i have the gear box apart?
Seams like there is no drive to the prop, HELP...
Horsley-Anarak, what sort of pictures are you looking for?
My work
Turn the prop by hand does the prop shaft move?
Post by Stelios_Rjk »
Critical question! It had happened twice to me, tried to turn the flywheel in vain. Luckily the first engine had sucked ropes that had stuck under the pump rotor and the second had a so rusted drive shaft that it had swollen and stuck in the shaft's housing :shock:
Are those bronze big end caps obtainable?
kitepaulx2
Yes prop turns just seams no connection between the two, like its out of gear?
My work
1650bullet
Post by 1650bullet »
kitepaulx2 wrote:Yes prop turns just seams no connection between the two, like its out of gear?
Does the prop turn on the prop shaft. eg; if your turning the prop, does the prop shaft turn with it. Or is it still.
Pictures please!
kitepaulx2
It has begun, took a while but at last have started to strip/look for the broken bits.
Drive shaft is oil all drained (was not much in there)
Can't get a further need the correct size allen key and rest of bolts/screws seized, so all sprayed with wd40.....
My work
