I want to extend the Villars cable
Captain Dave
Post by Captain Dave »
Cheers all, I am from the colonies (the furthest from you though, as I live in San Diego, CA) and I have a question that only a serious group of Seagull collectors can answer.
It is possible to extend the throttle lever approximately 8 feet in length so that the motor can be throttled up or down from a remote position...in this case about midship on a wooden pirouge boat. (you will have to google pirouge to see what I am trying to power.)
See, the boat is rather narrow, and to turn around to operate it would be a challenge. Remote steering is easy.
I have four seagulls now, three of which have been restored and one is waiting for me. All of mine are 40+ with the exception of a 40 Featherweight that I found in a barn and bought for about 20 pounds.
Anyway.. if anyone has ever solved this challenge, I would like to hear how.
Thanks,
Capt. Dave
USCG Master Captain
Re: I want to extend the Villars cable
8 feet should not be a problem.
Pop down to your local bicycle shop, and they will sell you the inner and outer cable.
Then all you need to do is solder on some ends.
The cable will need to be fairly straight, with no sharp bends.
Should work well.
I'm sure you can extend the cable to suit. Avoid any tight turns where possible. How about some pics of your boat with a seagull? We like pictures :D
Michael
Post by Michael »
Why not install a moped twist grip throttle on the standard length Seagull tiller arm, then use a tiller extension for the times you want to operate the boat from further forward
Captain Dave
Horsley-Anarak wrote:8 feet should not be a problem.
Should work well.
I am not familiar with the bike world...but it looks like I need to be!!!
thanks all... will follow up with a photo of the swamp boat. (actually they call them Gator-Boats in the states.)
I can just see the antics of starting a Gull and trying to get away from a pissed off Gator? :roll:
If like our crocks, an electric start is the way to go?
Little ones OK aye.
Big ones?
You can make a mould of the existing ends and then tin the inner new cable and form the ends with solder.
For the carby end I drilled a hole in timber using same diameter drill as lead nipple and did the same process.
If you buy a tandem rear brake cable (2.1 meters circa 7ft 10") it will come with the carb nipple already on the cable, leaving you only to work out what you going to use as a throttle.
1650bullet
Post by 1650bullet »
I have a 8 ft throttle cable here if you want it. All it will cost you is the postage to your address. I dont know what that would be. The postage could work out cheaper or more expensive than you purchasing one from were you are.
david
Post by david »
Collector Inspector sir, why are you having trouble with your crocs? Round here we just take their zimmer frames away. You can get £10 for 2 at the scrappy!
Captain Dave
1650bullet wrote:I have a 8 ft throttle cable here if you want it. All it will cost you is the postage to your address. I dont know what that would be. The postage could work out cheaper or more expensive than you purchasing one from were you are.
A genuine thanks for the offer, but this is something that I should take on myself. Do you have the cable because you used a Seagull remotely?
Captain Dave
david wrote:Collector Inspector sir, why are you having trouble with your crocs? Round here we just take their zimmer frames away. You can get £10 for 2 at the scrappy!
Ok, here we go... boy the English have certainly taken liberties with the language !!!
What is a zimmer frame?????
Post by Stelios_Rjk »
This is also a mystery to me :roll:
Crocs - A lesser used reference to old people.
phil
Post by phil »
Zimmer frame, what we call a walker in North America. Just learned this last week from someones post showing their motor on a " Zimmer frame" The scrap yard I go to gives them to me free, they said there is not enough aluminum weight to make them worth anything, well less than a dollar. Of course that is the old style ones without the wheels.
