Bluing stainless
Donald A
Bluing stainless
Post by Donald A »
A bit off topic, as charlesp would say, but I melted the plastic handle to one our saucepans - which sat on the top of the lid, as a bar of plastic in a recess in the lid - by inattention, so I thought if I melted it off altogether with a blowtorch (Go System mixed butane propane, fine jet), then I could put on a screw thru the hole in the middle, with a knob on, as a replacement
Not knowing about tempering, I now have got the plastic off, but I left the torch too long on the stainless lid, part of which is now a nice blue colour. Can anyone help me - can I get the nice stainless colour back, and how do I do it?
Donald A
Re: Bluing stainless
I have no idea what you are talking about :roll:
H-A wasting away loosing the will to live :?
Horsley-Anarak wrote:I have no idea what you are talking about :roll:
Try Google: bluing of stainless steel and the removal of, loads of info about on the subject.
phil
Post by phil »
Well it could be sanded off with 1000 or higher grit paper but then it would need to be polished. It was originally polished correct? Not sure which would be the most efficient polish to do the job on Stainless. Ideally you would need a few progressively fine polishing compounds and several buffing wheels. Messy job! Might be less of a hassle to buy a new one, unless you harbour desires to learn polishing.
Taspiper
Post by Taspiper »
Pickling paste for stainless pasivation available from welding supplies. Then polish with scotchbrite pad.
Cheers Rolf.
www.acmeengineering.com.au
www.rolfhey.com
Donald A
Post by Donald A »
[attachment=0]2013-06-28-0029.jpg[/attachment][attachment=1]2013-06-28-0028.jpg[/attachment]
Thank you for that - photos attached, which I hope will open
The set of copper bottomed stainless steel pans were a wedding present a long time ago, so have value to us, added to which it was my mistake that did it - as my wife says, quite rightly, if you look after well made things, they last a lifetime - which has a certain resonance in the light of my seagull enthusiasm.........
Donald A
Taspiper
Post by Taspiper »
If you want a real shiny finish you will have to buff after pickling.
Cheers Rolf.
www.rolfhey.com
Taspiper wrote:If you want a real shiny finish you will have to buff after pickling.
As Rolf has said. There are applications that when applied return the "Outer Layer" of stainless back to how it is expected to look like.
Do not abrade and do not use RTV...... :lol:
dandrews
Post by dandrews »
Can see no reason why not.....................give it a go aye?
Donald A
Post by Donald A »
Thank you all for the comments - that gets me started!
Donald A
