SAE 90 Gear oil in Canada
david doyle
Post by david doyle »
Not sure if this is helpful but my experience with finding SAE gear oils locally has been a tough so thought I'd pass it on.
Went to grab a litre of EP 90 for the merc and my local crappy tire has stocked SAE 90 marine gear oil. No it is not 140 but it is mineral based SAE and it is cheap. It seems that most seagullians and even British Seagull says EP is ok but SAE smells a hell of alot better and it is a few bucks cheaper per litre.
Below Is the info you need to get your local Canadian Tire to order it in. I specifically asked my local store a few months ago and they assured me that SAE90 did not exist :roll:
Motormaster
SAE 90
Formula 1 Marine Gear Oil
028-1700-4
1650bullet
Re: SAE 90 Gear oil in Canada
Post by 1650bullet »
Can you get Penrite oil in your area.
http://www.penriteoil.com.au/products.p ... roducts=82
david doyle
Bullet, Big thanks turns out there is a stocking dealer within 600kms. Closer then any other source I have found. Will call them monday and see if they have 140 on hand or if they can order it.
Located in Edmonton.
http://www.sportscarcentre.ca/
david doyle
Re: SAE 140 Gear oil in Canada
Talked to them today and yes 140 SAE is available and he will ship. 1 ($13.95)and 5 ($45.00) litre jugs. Aint cheap but it is available. Huge thanks to Bullet for nailing this one down.
Penrite SAE 140 gear oil
1650bullet
david doyle wrote:Talked to them today and yes 140 SAE is available and he will ship. 1 ($13.95)and 5 ($45.00) litre jugs. Aint cheap but it is available. Huge thanks to Bullet for nailing this one down.
That's about what we pay for it here in Oz.
CatiGull
Post by CatiGull »
I have found 140 weight gear oil available in the States in the NAPA chain of automobile parts stores - special order, but available at reasonable price.
Stephen
Awenke Yacht Club
New Baltimore NY
S/V Catigale
Macgregor 26X
Island 17 Sloop
fortyplus
Post by fortyplus »
I get SAE 140 from my local agricultural store apparently it's still used on farm machinery and you get a lifetimes supply as the can is huge for not many dollars.
SAE 90 can be bought in Walmart if nothing else in a Quicksilver brand but is pricey $11 for a quart.
