SD
markhld
SD
Post by markhld »
Hi Boys
Just to let you know that i am selling one of my army sd,s from my collection on ebay item no. 151144986416
It will give us all something to talk about.
Re: SD
Nice to see all the original bits. Is that bracket original? I've never seen one so can't comment on that. Best of luck.
Re: SD
That's one of the three original brackets known to still survive, if I had the room Mark I would be very tempted, one of the very best examples.
Re: SD
Post by Stelios_Rjk »
And I was wondering whether this is the original bracket or not!
markhld
Re: SD
Post by markhld »
Thanks Charles uk its a shame that you got no room. It would be nice to know its gone to someone that appreciates the motor.
Hi Stelios_Rjk the bracket on the engine is an original bracket for the military, As Charles said this is one of the three. I hope this helps you.
Re: SD
I imagine those brackets were cobbled together from angle iron in various places. The pictures off the SOS main site show a slightly different version. The drawing is more like Marks.
Mark, can you post some close ups of the bracket so we have them before you sell it? I have a skeletal bracket for my SD, but it's good to see this version finally.
SD bracket drg.jpg (34.55 KiB) Viewed 1779 times
Re: SD
I would suggest the photo's you've posted Adrian are of a cobbled together one, that's been modified to fit a wider gunnel, When Charles & I were researching I looked at 2 of the 3 known ones, both were type "B" & showed signs of very professional manufacture, bending angle iron through 180 degrees with less than a 2" radius without deforming it, is not a job for a blacksmith.
I don't know the weight but maybe Mark will weigh his.
I don't remember when the skeletal first came into existance, but I believe it was post war.
markhld
Re: SD
Post by markhld »
Hi Adrian ( oyster 49)
Yes not a problem with pictures of the bracket. As for the picture of johns bracket type B is right but with out me getting my paper work out i think mine is a type C. if you didnt know they did this type bracket from type A to D with a slight difference. Hope this answers your question on how many type of military brackets.
markhld
Re: SD
Post by markhld »
Hi, Charles and Adrian just to let you know that i have weighed the bracket and the total weight is 9 kg. ive also taken some more pictures of the bracket. I hope this helps.
