I am writing this post because I get some experience by experimenting and breaking parts
Brass-Bronze.
Brass is an alloy mainly consisting of Cu-Zn and it is usually yellow.
Bronze is an alloy mainly consisting of Cu-Sn and its color is usually close to the color of copper.
While restoring a Seagull I needed to bend a piece metal, brass or bronze. As I am not sure about the alloys I tried to bend I will use the colors when polished. Red or yellow.
I tried to bend yellow rods to form old type of thumb screws. After several experiments and broken rods I realized that it has to be glowing red when you try to bend it. The feeling is like the rod want to bend on its own. No serious effort. In case it requires effort and you continue pushing, it will probably brake. Try it to a piece of metal that you don't mind destroying it.
Let's go to the drama. A deformed bronze (red alloy) skeletal type transom bracket. Deformed due to damp package on shipping.
I thought the same method would work. Glowing red etc.. NOPE! It snapped like a carrot. It was awful and I was frustrated.
I went to a experienced welder to fix it. He did a nice job and I take care of the details. Satisfying result, OK as much as it could be.
I tried again on a red alloy part from a Seagull. Glowing red, same result, started cracking.
So, to come to a conclusion. Yellow parts can be bent while glowing red. Red parts, do not touch them!!!
