Modified Amal 400 series carbs.
I've been asked by a couple of overseas Seagull racers to supply them with new Amal carb bodies bored to different sizes.
So the following sizes will be available as bare bodies, if you want a complete carb ask John first as I have limited stocks of the bits.
416
417
418
419
420
420.5
421
421.5
This means I'm going to have to buy 2 strange sized reamers, if I spread the cost over a greater number of carbs, I will be able to lower the cost for all of us.
PM or email me, if you think a slightly larger carb might help you in your quest for speed in this years seagull races.
bercan
Re: Modified Amal 400 series carbs.
Post by bercan »
Really! I hope these guys are not from Bermuda..that would be cheating when it comes to the race.How do you tell if the carb body has been bored out??
I can't remember where those gentlemen are from, but as they're gentlemen, they probably are not Bermudian.
I might even return this June, just to show JJ the error of his ways & try to raise the bar on the unlimited record.
bercan
Post by bercan »
Hahahahahahahaha..thats too funny.looking forward to seeing you in june.If you need a place to stay I have a bedroom available.I race out of Mills creek,so Im not a gentalmen.Im a seagullian!
That's a very kind offer thanks, but I think I'm sorted, usually at the bottom of Collectors hill.
I won't admit to knowing anything about Mills Creek but give Charlie, Brian, Bert & Graham my regards.
That would be the slide bore?
More info please Mate.
bercan
Post by bercan »
you are making me a little nervous here...you seem to know alot about Bermuda and its hidden secrets..are you Santa Clause??
Bruce,.
No the carb size, so the carb throat can be anything from 16mm to 21.5mm depending on application not limited to 16, 18, 19 & 20mm.
Beercan.
I might be, I only turn up on one specific day the same day every year, I only visit the good boys, hence why we've never met, I have been known to bear gifts but usually return with more that are green in colour, I'm as Dean Gorman named me the "Slimey Limey", who are you?
I see, thanks Charles
bercan
Post by bercan »
Im Charlie Browns cousin,I used to run a dingy called Happy Snapper.I like the old school class.first to go last to finish,better ride,more comfy for the ladies and a way nicer way to see our sweet little island.
So your are off racing Charles.
