Piston rings for a Seabee Minor
Posted: Fri Feb 21, 2014 1:09 am
by robhc1000
Im after 2 piston rings for a seabee minor and my normal supplier does not have any so wondered if anyone on here had any spare they wanted to sell?
Re: Piston rings for a Seabee Minor
Posted: Fri Feb 21, 2014 8:57 am
What is the bore in mm
What is the depth of the piston ringland in mm
What is the height of the piston ringland in mm
Do not round off to a whole mm.
I get rings made if not available from my local sources.
Posted: Mon Feb 24, 2014 8:01 pm
by robhc1000
Collector Inspector wrote:What is the bore in mm
Thank you, will measure up, do you know approx cost to have them made?
Posted: Wed Feb 26, 2014 10:15 am
Cost.............. no at this time. Not expensive but need measurements first. It is the thickness/depth that determines a ring price when something not off the shelf is required.
Try local to you if any available first.
If you can not find rings, my price will be at cost plus postage to you or anybody on S.O.S.
Need dimensions as above as stated.
Posted: Fri Mar 07, 2014 8:29 pm
by robhc1000
Thanks Bruce, a uk supplier has had some made up, a set costs £23.50 posted.
One problem solved.
Posted: Sat Mar 08, 2014 8:32 am
Price about right!
Pics when doing work aye?
Posted: Sat Mar 08, 2014 11:58 am
by robhc1000
Collector Inspector wrote:Price about right!
Yes, will post pictures of work In progress, I cleaned points and got a spark yesterday
