SD/SDP gearbox end cap and Brass Tiller Arm needed
Post your wanted adds here
Hello all, would anyone by any chance have a spare SD or SDP gear box end cap (without filler bung) as the one I have is badly cracked, even a complete gear box will do,
Also I am after a brass tiller arm with the complete bushing and washers, even at a push if someone has just the bushing and washers as I have a fairly tired tiller arm that would do for now but with no bush.
Thank You
Re: SD/SDP gearbox end cap and Brass Tiller Arm needed
Sorry Rene, can't help on either I'm afraid. The only end caps I have have the filler plug.
Can't help re brass tiller but do have what appears to be an SD gearbox cap. It is probably off an AC/AD but to a visual inspection they appear to be the same. I have seen bunged caps on SD's so assume they are all interchangeable on 102's. Has the number 1259 if you can find the matching gearbox :D It weighs 367 grms and I'm on the other side of the world. Does Jan have any? Didn't all SD's have black painted steel tiller arms? I'm sure I've seen the bush and washers for sale somewhere.
Oh dear. I think it knows it has a new home.
Jan
Post by Jan »
I've all the parts if you still need them.
Must check the condition of the SD end cap when I'm in the shed.
Jan
Thank you guys, I will send you a PM
Rene
Jan
Post by Jan »
Hi Rene,
This is what I found in the shed.
Jan
That's it Jan :D
Will PM you
Jan, I thank you so much for helping me with the parts I needed, and Hugz for the offer, it is so nice to meet people that are driven by passion not money, especially in a little community like ours, very refreshing :D
