Ignition Spring
Philpy
Ignition Spring
Post by Philpy »
Hi,
I am looking for the spring which goes behind the points on a Wipac ignition. As seen here: http://www.classicseagulls.co.uk/images ... 0x333_.jpg
Anyone know where I could source one from?
Thanks
Re: Ignition Spring
can you be a bit more specific?
is it the very small coil spring or the larger strap (made of spring steel)
i'll have a look in some boxes of bits (i might have 1 0r 2) :D
Philpy
Re: Ignition Spring
Post by Philpy »
Its the coil spring, sorry should of said! Ive got a spare one from a villiars setup, but its quite different in size!
