Has anyone got any 7 to 7 1/2 inch prop or a larger size prop which I could customise?
I want to put the biggest prop possible on a featherweight gearbox.
Will pay plus postage/package, thanks emrys
7 to 7 1/2 propeller wanted?
Re: 7 to 7 1/2 propeller wanted?
What prop after you after (shape)
viewtopic.php?f=2&t=5592&hilit=props
Have a look in the thread above is it the 5 blade hydro fan? 4th prop down in the list.
When you say customise it what are you planning on doing to it?
Or use it as a pattern to cast a new one?
This one still needs a bit of a clean up! And it is a touchsmall for what you want.
Before you start buying props, it might pay you if you give some thought on, how your going to hang them on your featherweight prop shaft.
