Seagull outboard with forward/neutral/reverse
Seagull1975
Post by Seagull1975 »
I saw a YouTube video with a seagull century that had forward/neutral and reverse. Is this a special version of the seagull outboard or would it be something someone made themselves?
Re: Seagull outboard with forward/neutral/reverse
It's probably a model 90, have a look on the main pages there might be something in the FAQs about changing jets & a description of the Model 90.
Sorry, this is the best photo I have of an Electronic Forward Neutral Reverse (EFNR) Lots of info main site as above.
THCL500J8
Post by THCL500J8 »
ENFRL (Tasmanian Version)
Model 90
or one of these:
http://www.saving-old-seagulls.co.uk/i_ ... series.htm
Or a QB Series
The FNR basically is still a dog clutch like other seagulls but there are two crown wheels, which the dog clutch can engage either of. As they rotate in opposite directions you can drive the prop either way. Quite a neat arrangement. I believe the actual long rod can be prone to sticking if not maintained for long periods.
Buzzook
Post by Buzzook »
Yeah, had the same problem with my Model 75. The stainless rod corrodes itself to the gearbox housing.
I freed it up by placing it over a gas stove, then plunging it into a bucket of water. Repeat till rod is free.
