puff puff
Post your wanted adds here
Alfabud
puff puff
Post by Alfabud »
am looking for a pump to blow up my dinghy..the one av got is pretty much useless..am not sure about the ones on ebay ..don't know if they r any good or not..anybody know what is the best air pump.
you live and learn, then you die and forget it all.
Re: puff puff
I have a 2.6m inflatable, with a foot pump, it takes about five minutes to blow up, faster if I get someone else to do it.
I don't pump up the boat next to the car, so an electric one is out, they are OK for inflating something large, as the push a lot of air, but not with much pressure, so you would have to finish off pumping with a foot pump, unless you pay for a good one.
One found example on the net.
https://airkayaks.wordpress.com/2014/10 ... dle-board/
Re: puff puff
I have a cheap 12v plastic chineseee thing. About 8 quid that plugs into my cigarette lighter. I then use a double action hand pump that blows on both up and down stroke to get final pressure. Only a few strokes for each chamber. You can see both pumps at 14 seconds. Note if you put the electric pump on gravel it sucks up stone and spits out broken impeller. Note you will need a pump that sucks out air to be able to get it back into its bag.
https://www.youtube.com/watch?v=h9UswYi1SgA
http://www.ebay.com.au/itm/COMPACT-POWE ... Swys5WWa8p
Alfabud
Re: puff puff
Post by Alfabud »
Keith.P wrote:I have a 2.6m inflatable, with a foot pump, it takes about five minutes to blow up, faster if I get someone else to do it.
think I will try that one...av got a bellows pump but its not much use...this looks a bit better...
Alfabud
Re: puff puff
Post by Alfabud »
bought that 1 that was good...when u pump up or down it still pumps air,so yes good 1
