Marston Parts
Post your wanted adds here
seagull101
Marston Parts
Post by seagull101 »
Hello everyone,
I'm desperately after a KLG screw on plug cap and a pink Lodge C3 plug for my Marston OP.
Pics attached as its all the same as whats on my SD.
PM me please.
Jacob
seagull101
Re: Marston Parts
Also after a marston tiller grip, forgot about it when creating this thread.
Re: Marston Parts
Lodge C3 are not that hard to find, just only when you need one, plug caps are getting a little harder to find and more expensive as time goes on.
You need a KLG because the HT spade is wider then the later Ht leads, one reason why I have a KLG on my wartime motor and Champion's on the rest.
Like yourself I like to see the correct plug and cap on a motor, start collecting, I did.
seagull101
Re: Marston Parts
Plug now sorted (thanks Tam) but still on the lookout for a tiller grip and plug cap.
Jacob
Re: Marston Parts
Is that block Galvanized or painted ?
Re: Marston Parts
That looks like silver paint to me. The tiller grips will be an interesting sourcing exercise. I'd suggest looking at classic motorcycle and lawnmower suppliers, I know of a company called classic grips, who sell a range of grips. I'm not even sure of the correct grip for the different pre war engines.
seagull101
Re: Marston Parts
Yes, the whole powerhead is painted silver exactly the same as the crated one that was for sale last year.
I will do some research about grips and will post what i find here.
Jacob
Re: Marston Parts
I've often seen a lot of older 102 blocks (short and long water jacket) with missing black paint on them, and when i've fully removed the black paint it's revealed a galvanised coating much like in the pictures. Nice to see them not painted black for once :P
Re: Marston Parts
I have seen 2 new SD cylinders (obtained from military spares) both black painted, chipped paint no trace of any zinc, fully greased up with the piston, pin & rings inside but no water fittings at all.
timberman2004
Re: Marston Parts
Post by timberman2004 »
Hmmmm
one of my wartime SD's has what fully appears to be a galvanised block ...not a trace of paint
Re: Marston Parts
All the SDs I have owned (Approx 8 and the spare block I have have the "Dipped zinc" style of surface finish. This could look like a dullish silver finish?
Its always been the assumption here that this was a rough and ready finish for the ministry of supply, as it does not seem to have carried on onto the long water jackets in the post war period.
A few seem to have lasted very well!
Re: Marston Parts
eBay No. 171691476245 :roll:
Re: Marston Parts
An English made somewhat accurate reproduction part, but its pretty obvious its not original looking at the colour.
Re: Marston Parts
headdownarseup wrote:I've often seen a lot of older 102 blocks (short and long water jacket) with missing black paint on them, and when i've fully removed the black paint it's revealed a galvanised coating much like in the pictures. Nice to see them not painted black for once :P
The paint on this was done by brush somewhere in the past....... like black board paint
BnC[/color][/b]
Re: Marston Parts
I must have seen a few blocks that look just like this.
If anyone was wondering, some of the earlier long waterjacket cylinders can sometimes look like this as well. (more hex-headed core plugs rather than slotted plugs)
What i'd really like to know is what do the more seasoned members do to their cylinders as part of a restoration. Paint them or leave as is?
Interesting isn't it? Why are some painted black and some are left silver.
