New Seagull parts for sale.
It's time I started to clear some space, by selling some of the new Seagull parts I've collected over the last 25 years, that I won't live long enough to use, as it would cause me great distress if they ended up as land fill.
New 170 crankshafts, no conrods.
New Century crankshafts, might have a couple of conrods.
New 40 series crankshafts, might have a couple of rods.
New Kingfisher crankshafts can be with new Kingfisher rods.
I also have some new cylinders.
New century 100 cylinder for Villiers carb.
New SD 102 cylinder with piston inside still in wartime packing grease.
New 170 cylinder with new piston.
I also have 2 good used SD cylinders.
I have no idea of the value of any of the above, as I avoid ebay to prevent me buying more clutter.
If your interested in any of these spares make me an offer, best offer get first pick!
Will ship anywhere, your paying for the postage, contact me by email or PM.
This is only a couple of drawers, there are a lot more, if there's anything that's no longer available you need, you can always ask, if John doesn't have it, I might.
Please give me some of my money back, Charles.
joppe
Re: New Seagull parts for sale.
Post by joppe »
Hello charles,
I am interested in a sd cilinder and piston, got a sd carb as well?
Thanks
Jan
Sorry Jan no SD carbs.
If your interested in the New SD cylinder & piston, it is just a new cylinder with no water fittings & with a piston & wrist pin greased in the cylinder, I don't know if it has rings on the piston.
2 other people are interested, so I've told them all to make their best offer by next sunday by email.
joppe
Post by joppe »
Hello Charles,
Try to send you a pm several times but i gues it didnt work.
If you still have a used sd cilinder i need one to fix mine.
Thanks Jan
Did you get my email Jan?
I need your landline number & I'll give you a ring.
joppe
Post by joppe »
No sorry charles, didnt get your email.
I havent got a landline.
Best to use my mailadress joppe@zeelandnet.nl
Thanks Jan
Jan your email address doesn't work
The address is valid Charles
