fitting a wipac marc 3 coil
Kevin O Connor
I have a new coil and trigger on order. When they arrive I intend to put them into my silver century 102. Is there anything I need to know or is it a simple switch over. Thanks in advance.
Re: fitting a wipac marc 3 coil
What's the engine number of your silver century, & are you just replacing a faulty CDI?
Kevin O Connor
EFPC255K5GFP456CC7, YES THERE IS NO SPARK AT ALL, WHEN i TRIED TO SET THE POINTS i DESCOVERED THERE WERE NONE JUST A COIL AND TRIGGER UNIT. i CONTACTED jOHN AND HE TOLD ME IT WAS A MARC 3 AND CANNOT BE REPAIRE
KEVIND BUT NEEDS REPLACING.
Kevin O Connor
Sorry I just checked it is a forty plus, not a 120. It is one of the barge pusher types.
Kevin O Connor
Sorry again, that is the wrong number. The right one is ESPCL1818AA0. I must be getting doddery in my old age. Looked at the wrong page in the notebook.
Kevin O Connor
The reason I am asking what seems to be a silly question is because I have heard people mention sealing the coil after fitting. Any ideas on how to do this would be great, thanks.
Hello Kevin
As far as I am aware the only sealing is on the HT lead as it comes out of the coil. This needs to be sealed with silicone once fitted.
Hope this helps.
SOS
Hope this helps.
SOS
Kevin O Connor
Very much oblidged John. Thank you.
