ESC backfire, starting protocol, etc
My ESC is back together and I have been getting acquainted with its best starting protocol. It has the the Seagull-AMAL curberetter. When cold, I use full choke, gears in neutral, full throttle. As soon as it starts, I back off throttle to 1/2, open choke, throw it in gear. Goes well with water in trash can just over cavitation plate. As experiment filled trash can more until motor bogged and stopped. Emptied barrel to previous level.
Now had trouble starting when warmed up (but not HOT!) Fiddled, pulled, cussed, groaned. Backfire through carburetter. Repeated the FPCG process and got it started.
Some questions:
Why the backfire?
I saw in a post here that carbs are sensitive to being level, or nearly so. Could this have been the statrting problem? My test stand/transom subsitute is vertical giving a slight forward tilt to the motor.
Second, the air intake choke shutter assembly is made of Godawful black plastic which strikes me as a bit chintzy and fragile. Is there a bettter solution?
Much thanks. I am kicking myself for not preparing eariier, as today is one of those days that makes in worthwhile to live in New England with its too frequent lousy weather and cold sowy climate, and I should be floating rather than fiddling.
Some questions:
Why the backfire?
Backfire through the carb can be sign that the mixture is weak, which could be due to adjustment or dirt in the jet. (the infamous lean sneeze)
The points gap being too small will delay the spark not make it early, too wide will make it early.
Not had any problems with a vertical mount either on the test stand or the boat transom but i may have set the carb on its fixing so that it is level (Villiers carb)
Thx all for comments
Vic: Amal has no mixture adjustment.
Will recheck points and plug gap.
Redycliffe (not HEATHcliffe?): Choke shutter on my Villiers carb is metal also. BUT the AMAL unit is flimsy black plastic. Is there a metal assembly available for the AMAL?
Vic, et all:
Just checked (not REchecked) points gap. Almost nil. Would motor run at all with points closed, or almost closed?
Took magneto off another motor, in too big a hurry to check point gap! My bad. My VERY bad. Live and learn.
Leaves only plastic choke assembly to deal with!
Again my thx
Again my thx
- Rob Ripley
starting problems
My 102 starts every time (cold or hot) minus the prop. in a tank, and runs smoothly at all speeds.
In the water (I have no clutch) it will start easily on almost full throttle, but runs, misfires, spits out the carby (no choke either) etc, and then after 30 seconds or so settles down to smooth running. It does this hot or cold.
If the points dont open at all it wont run. If the gap is very small it will make the spark very late, but i cant quantify that.Just checked (not REchecked) points gap. Almost nil. Would motor run at all with points closed, or almost closed
Are you sure you are looking at the points when they are open at their widest?
backfires
If a Seagull has the points set up correctly at 0.5mm or 20 thou for points ignitions, and the plug the same, I would suspect the petrol/air mix was weak.
Is it sucking air past the bearings or through the joint in the crankcase? look for bubbles being blown through the same crack.
Try 10:1 mix till you get lots of oil round dry bearings.. just a pint of mix, then go back to 25:1
Watch the depth of the motor too. the straight exhaust tube should have the bottom edge 2 inches under water. Sounds like yours is not deep enough for the pump to be covered... If it is not, it will not pump water... Effects the back pressure in the pipe too....
Water level
Yes Bruce there certainly is.
All seagulls are designed to have the bottom edge of the exhaust tube 1 or 2 inches max immersed. The bottom of the tube, not the outlet ..
Any less and they will not pump, as the pump will suck air and more and there can be starting problems and lower power because of back pressure in the exhaust.
SOS
SOS
