Villiers carb please help!!
S2P2G
Post by S2P2G »
HI ITS STEVE ET DOM AGAIN
CAN SOME ONE PLEASE TELL US HOW TO GET THE BLACK BOWL OFF THE
Villiers carb,BEFORE I BREAK IT.!!
niander
Post by niander »
unscrew it...normal way...
Vic
Post by Vic »
normal way
IE Right hand thread
S2P2G
IT JUST TURNS AND TURNS ??
Post by S2P2G »
Vic
Post by Vic »
It's screwed onto the bottom of the centrepiece/jet assembly. Is that turning because the little grub-screw that retains it is missing (see part #11 and #13 in this diagram from John's site
If the centrepiece is not turning then the threaded insert in the base of the bowl has come loose.
Note that the aforementioned grub-screw locates in the machined slot in the shoulder of the centrepiece not the round hole
