Following on my post in Dohnut's thread, I thought I had exactly the same symptoms as his 40+.
However, prolonged attempts at starting have lead to a sudden new development - the crankshaft has gone very stiff to turn. It is impossible to spin the flywheel with the cord, and hardly possible with two hands.
What could have happened - does this point to a piston ring fault, broken perhaps? The compression had always been excellent before this.
Crankshaft suddenly seized up
Clifford Pope
Could it be a problem down at the gearbox / prop end rather than the power head? does your have a clutch?
Have to confess I thought my dear old 40 was partially seized once only to look down and see the prop cutting into the lawn as I was holding motor at the wrong angle ......
Not suggesting you have done that of course but it could be a jam in the gears perhaps? partially engaged clutch? Separating the gearbox from the motor would prove it obviously.
I only mention it as it would be unusual for a motor to seize ( or partially so ) while not running assuming petrol / oil mix is ok. You could try putting some hot oil down the spark plug hole and see if that frees things up after some turning of the motor. Take great care of course.
Clifford Pope
No, it's stiff all the time, doesn't change at TDC. It's not the prop end, and there is no clutch. It looks like I'll have to open up the engine and look at the rigs and bearings.
It seems an odd coincidence that it has happened so suddenly but not while running, and hasn't run since it cut out. Can a crankshaft seal fail in a way that firstly it leaks, and then jams the shaft?
Clifford Pope
I don't know the design in detail - I just assumed there must be some kind of seal stopping inlet gases leaking past the crankshaft bearings.
As luck would have it, I have just been given another identical model from someone's garage, and after cleaning up the plugs, points and fuel filter, it runs. I've had to pinch the bracket and carb from the first one, so I'll postpone the PM for a while.
Thanks for your suggestions.
