Went to get some new plugs for my 'flock', (102, C100, 40+), Champion not available and NGK AB-6 have replaced the origonal NGK plugs.
Any comments?
spark plugs
- Rob Ripley
Hi Rob - we can get Champion D16's here reasonably easily, the NGK's are fine, and Bosch either do or did an 18mm plug until quite recently - any 1/2" reach 18mm plug will do, as I think they all have a pretty similar heat range.
Most Seagulls I run into (with their owners) are still using the original -or at least very old - plugs, not that I necessarily approve.
Try contacting old car or stationary engine clubs, and I'm sure John is able to supply you -- Rick
- Rob Ripley
spark plugs
Thanks for the reply Rick, I bought 2 (they had several packets) for A$6.00, which is around 2.96 UK Pounds.
According to THIS CHART NGK AB-6 are 20.8mm reach.
According to This List NGK A-6 are the equivalents of Champion D16
Personally I use 8COM in my two Seagulls but I only have one spare left now!
