Vic wrote:
I would be interested in what you think of the dinghy though. I think the 3 person one might satisfy a need I have for a small light and cheap dinghy.
Right, finally got tyhe chance (a) to reply and (b) to try out the boat on the water!! Yes, I know it's been some time since my original post, gimme a break I've been busy
I ended up buying a Yamaha P-45 from a friend of my wife's uncle. These are I'd hazard a guess even more scarce than Seagulls as they stopped building them in 1979! First attempt on the water it just would not start, depsite a new plug and checked points. I had managed to get a manual for it via Ebay, from a marine repair place in Australia of all places, and had ordered new ignition parts (points, condenser, coil with integral HT lead) and got them fitted end of last week. I took the carb to bits yesterday and what I can only describe as limescale came out of the float bowl
Now, this thing has not been run in seawater, the metal & paint/powder coat is in far too good nick for that, so I can only assume this is 30* years of hardened accummulated crud. Anyhoo, blew it through with my air line, reassembled it with all of the new ignition bits and once on my patent motor stand in a dustbin of water, first pull off she went.
So, to the point of this post, the boat. As said before it's an Intex Excursion 5, bought from an Ebay supplier in Germany via Ebay Spain or Portugal (can't remember which) as it was much cheaper than buying in the UK! £47.98 + £32 postage wasn't bad I thought.
It's got three buoyancy chambers (the floor and an inner & outer hull), 2 inflatable seats with backrests and one inflatable mid-position seat. The onyl annoyance is that the hull inflation valves are Boston-type, albeit budget ones, whereas the floor is a beachball-type one way valve. This wouldn't be a problem but the inflation pump has a large nozzle to fit the Boston valves and this also fits the floor valve, but doesn't hold open the one-way flap inside said valve, making pumping the floor up a bit of an effort!
Once this was done it was the work of moments to attach the motor mount, get it in the water, attach the motor and get going. It handled very well, but being a flat floored type was susceptible to being pushed about a little by the wind. The stern also collapsed in a little as it was being pushed inward by the thrust from the motor on the mounts, so I can see myself devising an aluminium/plastic alternative which pushes more evenly against the hull than this one.
The only real negative I can come up with is that the floor partially deflated, not a calamity in itself as this boat has plenty of reserve buoyancy but a pain on it's maiden voyage all the same! I''l see if I can localise the leak as it will make this boat about perfect for me and mine!
