long shaft exhaust,clutch lever,water pipe,clutch rod
Post your wanted adds here
Niander101
Post by Niander101 »
wanted large long shaft seagull aluminium exhaust [with the 2 small holes]no dents please 22" lg
also standard clutch lever with ball on end
also clutch rod 31 1/4 "
also water pipe 23 1/4 "
Re: long shaft exhaust,clutch lever,water pipe,clutch rod
Is it not easier to buy a whole engine as you need the powerhead as well?
Niander101
probably im looking!
Niander101
Im sorted for this now also!
