History behind it is not very clear. All I know at this stage is that it was (possibly) a one owner outboard until it was shipped down from Queensland and stored in a shed on a large rural property ever since.
All original from what I can tell, including the Salmon/Gold paint. External finish is faded, engine and edges of the upper and lower cowl sections reveal the actual color. Lots of rust and corrosion under the paint, and flaking paint in a number of areas indicating salt water use and perhaps a lack of general maintenance. All will need to be redone.
Turns over very nicely and has good compression. Not quite sure about the ignition system and coil/s I have not had a chance to remove the flywheel to inspect and test them as yet.
Gear and throttle levers operate as they should albeit a little on the tight side due to the build up of grease and dirt over the years. Throttle knob is broken. Would have preferred this was not the case but will have two new ones spun up on a friends lathe.
A few holes in the upper and lower cowls (visible in the above pic) drilled by the previous owner, one being for a key operated kill switch, the others unknown. These will need to be welded/filled.
Overall not in too bad shape.
I am real excited about this find and am looking forward to getting stuck in once I clear a few other unfinished projects.
