Airfilter Seagull Type WSPCL1284D1
Defess
Post by Defess »
Hi All
I wonder is here an air filter? Or should there be an air filter?
I got the thing with the choke assembly mounted on the carb, but I can't see any filter in it.
Many thanks for the help
Best regards
Anders, Denmark
British Seagull engine Serial Number: WSPCL1284D1 - Silver Century, Plus Clutch Drive, Ignition: Wipac Mk 2, Carburetor: Amal
AusOB_Collector
Re: Airfilter Seagull Type WSPCL1284D1
Post by AusOB_Collector »
Hello and welcome to the forum!
Could you post a pic of the carburettor your motor currently has fitted?
The WSPC's had either an AMAL 416 carb or an AMAL twin-jet carb I believe.
I have attached pics of both types of carbies below.
Thanks to SOS for the exploded diagram
BP
Amal 2-jet.jpg (9.29 KiB) Viewed 5146 times
Member SOS, AOMCI,
Defess
Post by Defess »
Hallo BP
It's the one below. Defiantly
Best regards
Anders, Denmark
No filter
Defess
Post by Defess »
OK, Thanks´
Best regards
Anders, Denmark
chris
Post by chris »
there are no air filters on seagull carbies
THCL500J8
Post by THCL500J8 »
When these engines were built British air did require filtering. :) :) :lol:
Didn't the later forties have an air filter? The square box arrangement.
No Seagulls ever had an air filter, just covers to prevent them sucking in spray, though some of the later inboards (SD110 & SD160) had the carb inside a cast aluminium "box" to prevent fuel dripping from the carb onto the very hot exhaust header & starting a fire inside the motor cover.
Apparently this was caused, by it happening when a staff member was taking a party of school kids for a joy ride around Holes bay in the inboard demonstrator, don't know what all the fuss was about, as there doesn't seem to be a shortage of kids around here!
An air filter would have made a lot of sense as the UK is famous for it's dust storms over bodies of water!
We had dust storms today so bad we had to dress like this.....
