Anyway, following pics tell the story, but will kick off with a snap of some information received from Barry Sheltrum, son of Len Sheltrum founder of the Riptide Outboard Motor Company.
First task was to make the gaskets needed before reassembly could commence. Ended up using 1.2mm compressed fiber rated at 400C albeit that the temperatures will never get that high.
Moved on to the trunk thinking I could then use this as a work platform only to realise that I don't have any spare outboard stands. No big deal, it needed to be reassembled anyway.
The blue stuff is just high build primer overspray all of which has now been removed.
Repainted the base section inside lower cowl ie to reflect the original paint scheme.
Single gasket for engine and exhaust ie again to reflect the original set up.
Looking a lot more respectable under here now.
Just a point to note. Water pick up must be connected before the mid-section is refitted. Will be leaving that till next week. Probably wise to seal the tube to the rubber grommet ie to prevent any possibility of it falling out during water pump/impeller replacement.
Support bracket, fuel bowl and crank case fittings
Carb and magneto fitted for the purpose of checking operation of synch ie with linkages fitted. This confirmed the bend in synch plate was excessive, causing it to foul against the linkages as the magneto was rotated throughout its range. Straightened the synch plate. It now clears the linkages and provides WOT which we didn't have before. Carb will be removed again to facilitate re-assembly of the forward/neutral linkages and allow for shift shaft adjustment.
More next week.
