Pothauler
charlesp
Pothauler
Post by charlesp »
Anyone ever seen one of these?
An ingenious device from the Emerald Isle:
Using the power of a Seagull to haul lobster and crab pots from the bottom is a truly wonderful idea!
Re: Pothauler
I like the safety lanyard idea, if you get a really full pot it would stop the Seagull & hauler joining it on the seabed!
charlesp
Re: Pothauler
Post by charlesp »
I'm particularly full of admiration for the G Cramp that seems to secure the thing to the boat!
In the past I have wondered if a similar device might be contrived for hauling in an anchor, an activity which leaves me breathless and trembling!
Gannet
Re: Pothauler
Post by Gannet »
If the drive is being taken from the crankshaft threads, wouldn't there be a tendency for it to come unscrewed? Or have I misunderstood something?
Liam2k3
Re: Pothauler
Post by Liam2k3 »
I was thinking of something along those lines to run a permanent magnet motor and rectifier out of a wind turbine to charge my battery and run my 12v coolbox. I will mock it up later and post a pic.
Liam2k3
Re: Pothauler
Post by Liam2k3 »
Wonder what the gear reduction is in that winch. More info please
charlesp
Re: Pothauler
Post by charlesp »
Liam I have no technical information such as gear reduction. The photo is from a brochure that merely suggests that it's a good thing!
Re: Pothauler
Good point Jeremy!
Probably a fancy flywheel nut with an inner & outer on the flexy drive, put the hauler in gear when the Seagull's out of gear, complicated!
Liam2k3
Re: Pothauler
Post by Liam2k3 »
Pto Generator idea. Just need some sort of hinge bracket so that i can lift up the generator to start the engine.
Liam2k3
Re: Pothauler
Post by Liam2k3 »
Generator
Grumpy
Re: Pothauler
Post by Grumpy »
An excellent idea but nowhere strong enough for the amount of fish I catch.
My father left me an Allison 12cylinder aircraft engine from ww2 in going condition and as soon as I get everything into order and all the planning done I propose to install it in my surviving vessel..
I do realise that there is a host of problems to overcome including ballast available freeboard ,fuel tanks, hull improvements esp in the buoyancy area but I look forward to the day I can drop anchor in the deep blue, hurtle down some nets to whatever depth required then at the flick of a switch the nets will rocket upwards and there is my catch for the day.Maybe some for a later day as well.Reckon this Allison could provide me with enough grunt to fill up the onboard fish bins as quick as. at least quicker than this seagull assisted hauler.
I didn't get where I am today by not keeping my eyes open for opportunities .
Any sensible suggestions most welcome.
Liam2k3
Re: Pothauler
Post by Liam2k3 »
If you try and pull the nets up at the speed of light will it not just drag the boat deeper or under. That could be very funny to watch. If you ever do get it together please video it.
Re: Pothauler
charlesp wrote:Anyone ever seen one of these?
I can not see this as a reality.......
Everyone has one of these hanging on a nail for porting and polishing I would think. I have many different lengths and diams depending on what load Is applied. I use my post drill as a power source.
So looking at this attachment onna Gull all I can see is the nut wanting to unscrew when reactive load of hauler is applied.
Makes no sense to me at all at all.
Maybe the nut holds an adapter plate thingywhatnamedoodaddy that drives the flex shaft.
Also the engineer in me screams "WHERE IS THE CLUTCH" and "THE FREEKIN BRAKE" as once the rope is bedded to the winch sheave it is digital.
I can only see so much to go wrong with this design. Concept is novel though.
BnC[/color][/b]
Re: Pothauler
Liam2k3 wrote:Generator
That is thinking out of the square Mate.
Love it!
Re: Pothauler
Love it!
And just think outside the same square and leave it attached all the time......
Hint: "Tie your shoe laces backwards".........you will twig I am sure :P
