clutch lever 102
waterworks
clutch lever 102
Post by waterworks »
Anyone tell me the correct way the lever goes on the stud ?
My guess is spring first, then lever through the large beveled hole, then washer and nut ?
The bolt through the main tube locking ring should be at the spark plug end ?
The end of the operating rod should ride over the locking ring to keep it out of gear ?
Re: clutch lever 102
Lever first, spring, washer, nut, clip.
The end of the operating rod should ride over the locking ring to keep it out of gear?
Yes.
Look at the clamp, one small part is not rounded, that's the part you line up to the end of the rod.
waterworks
OK got it now, thanks.
