Ignition Engine WSPCL1284D1
Defess
Post by Defess »
Hi all good enthusiasts
I just got my first Seagull engine. A very nice one with all parts intact. As far that I can see.
There is a problem. I got no spark. I have tried the spark plug some where else and it work.
I put my ohm controller on the pointers and I can see I got connection both with open and closed pointers. I have cleaned them both. Why is that?
Many thanks for the help
Best regards
Anders, Denmark
British Seagull engine Serial Number: WSPCL1284D1 - Silver Century, Plus Clutch Drive, Ignition: Wipac Mk 2, Carburetor: Amal
Re: Ignition Engine WSPCL1284D1
Remove the condenser wire and try again. (Probably Wipac so just disconnect the coil wire)
If the same then pull out the points, pull them apart and clean everything.
If only with condenser/coil connected...................duff condenser.
Defess
Post by Defess »
Hi
Thanks for your quick reply. I will try tomorrow.
Best regards
Anders, Denmark
Defess
Post by Defess »
I wunder, is there an on/OFF switch somewhere?
Best regards
Anders, Denmark
No one/off switch. It's basically off unless the flywheel is rotating, in which case the magneto starts to develop a spark. If no rotating then nothing happens. On much later engines a kill switch was added.
So How is the Ignition delving progressing ?
